How to Carry a Trike on a Car
Discussion in 'Gear and Equipment' started by LeakyDuck, Aug 24, 2007.  |  Print Topic
  1. LeakyDuck
    LeakyDuck Email Defunct
    Palmdale
    Sofrider
    Darby
    I have a SUN EZ-3 SX and a Chevy Cavalier and I want to go to Ventura CA to ride with a recumbent club up there. Since Ventura is 100 mi. from here I needed to be able to load the trike on the car. I had seen mention on another list about using a standard bike rack on the back of a car, putting the front axle on the bike rack and setting the rear wheel on the roof of the car. figured it could work for a delta and went off to the local thrift store. This is what I found.
    http://home.earthlink.net/~leakyduck/rack.gif
    With the bike loaded:
    http://home.earthlink.net/~leakyduck/rear.gif
    http://home.earthlink.net/~leakyduck/front.gif
    Took it for a test drive and every thing stayed where it belongs.
  2. Geyatautsilvsgi
    Now that is an interesting delta...haven't seen one quite like that.
  3. Rocketmantn
    So how well did it work. Did it leave a mark on the top of your car? Very interesting idea. Was it hard to get your delta trike up there?
  4. LeakyDuck
    Palmdale
    Sofrider
    Darby
    No mark on top of the car - it kind of dimpled the roof when I tightened down the ratchet strap. Takes 2 people, one on either side. Put bunge cord on front wheel to frame so it doesn't flop around when you are lifting it.
    Total cost - rach from thrift store 5.95 - 2 racheting tie downs * 10.00 each. The car has been hit twice so a little scratching really isn't a problem.
  5. WardJ
    Thats Great!
    I really like seeing innovation. I am curious to see what it does to your mpg.
    Ward
  6. LeakyDuck
    Palmdale
    Sofrider
    Darby
    I have a 3/4 T Pick-up and carrying the trike in that is easy, but it gets 10mpg at the best. The car gets around 30mpg, so I can lose a few mpg and still be ahead.
    In our trial run to only problem we found was that the nylon strap holding the front down hums in the wind, really loud. I can stand the noise as long as I can take my trike and go places.
  7. laidback cyclist
    You could get a single roof bar type set up (either bought used or fabricated) and a short wheel tray (intended for a rear wheel). Attach the wheel tray to the cross bar and wal-la, no dimpled roof.
    You'd still need the tiedowns. Rope could also work for this (instead of straps) by using a "trucker's hitch". The rope probably wouldn't hum as bad. That's what I use for bow tie downs for the kayaks and I don't get any humming going down the road.
  8. A.D.
    Interesting setup. Luveagles has a PT Cruiser and does just the opposite with her WizWheels trike. She mounted a standard bike rack (similar to yours) on the hatchback and sits the two front wheels onto the rack via the axle/crossbar, then allows the rear wheel to hang down towards the ground and rest upon the rear bumper. A couple of straps around the axle/crossbar and one bungie cord to the rear bumper holds it all in place. :jiggy9:
  9. dragnfly
    dragnfly
    Springfield
    Path Infiniti
    Shawn
    :laugh9: Really easy folks if you've got a car trade the car in for a Pickup and you can either if you have a cover for the bed of the truck just strap it to the top of the cover, or if you don't have a cover on the bed just put it in the bed of the truck. If you have a Van or SUV. Easier yet put the seat, and handle bars down if it's an OSS. if it's a uss don't have to worry about the handle bars. Just ask me I've had to do just about everyone of the suggestions I just typed. Only one I have done yet is put it on top of a car Thank God LOL.
    Cheers
    dragnfly
    That is what I did with my Wiz Wheelz trike. Worked great!!!
